I have RAVENHEAT RSF 820/20t and problem with it, when I open hot water tap water coming hot and after about a minute getting warm only.
When i turn DHW thermostat to minimum is the similar situation at the beginning water is warm then getting cold.
I have replaced DHW thermostat I can hear is clicking means working but it look like is not reacting quick enough.
I check on diagram impulse from thermostat is going to PCB and I don't know what is basically mechanically make this water hot or cold because burner work perfectly, CH works OK . Diverted valve has been replaced as well.
If somebody can help, pls.
