I've recently bought an old farmhouse, built circa 1880. It's of solid construction (or so my surveyor told me) but with the usual problems of rising damp and woodworm which we're currently sorting.
The house has 670mm/26" stone walls, with a centre 340mm/13" wall which runs parallel to the gable ends. The first floor joists run from this wall to the gable ends.
Our first project for the house is knocking down a dividing wall between the old parlour (room with a wooden floor) and the kitchen. The dividing wall is of stone construction, and does not have a wall directly above. There is a stud wall on the floor above, but this is about 600mm away.
Would I need an RSJ for this? I'll be getting a structural engineer in eventually, but I just like to hear opinions. Would padstones be needed, or will the stone wall be sufficient?
Our other idea is to open up the gable end wall where the kitchen is. There is already a window there (with probably a slate lintel) which we'd like to open up into a doorway about 3m in length. As stated above the wall is roughly 670mm/26" thick stone built. Can anyone give a ballpark figure on costs for this kind of job?
Thanks for your help,
steve
steve
