Planning on rear extension on a end terrace house.Will be going through building regs and a proper insured structural engineer.Just looking for general advice with regards to requirements,so I could get a rough idea of costings.
Please see attached pictures.(they are current house elevation and what is proposed)What would be required if i need to remove the external rear wall and side wall of the house in just the kitchen area.Am I looking at RSJ or a goal post beam which obviously be more expensive.
How does a structural engineer decide if the loading on the wall is sufficient for RSJ without checking the foundations.Is it by default or hit and trial basis.After all he does all the calculations,which is then passed by building control and then the builder takes over.But who is responsible for checking foundations loads.
Finally what is the maximum load a solid 9" wall can take.In my case if he majority of rear wall is taken off and the RSJ is on 2 colums on each end,will it be sufficient.
View media item 79397
View media item 79398
View media item 79399
