Anyone know how to calculate a correct size RSJ please?
The house is a run down Victorian(1860) semidetached '2 up 2 down' cottage built from soft red-brick with lime mortar.
The opening in the load bearing living-room/kitchen dividing wall will be 2.2 metres wide and the wood joists (7"x 3.25") in the two above bedroom floors will be part supported by this RSJ. To make matters more complicated, though it shouldn't affect the calculation, one bedroom floor is 7 inches lower than the other bedroom hence my specification of a Rolled Steel Joist which will have to have joist hangers welded or bolted to one side.
I have not yet applied for Building Regs permission as money is tight nor can I afford to employ an architect or civil engineer for the same reason, I am a time-served electrician who went bust ten years ago and this is the first house we've bought since then - I have to do all the renovation work myself but am well aware of my duty to comply with Building Regulations. Any help will be appreciated, thanks.
