Im looking to remove 2 internal doorways from kitchen to utility and open up.
the house is a bungalow. internal wall is in effect the external house wall leading to what used to be an outside tool shed which we have changed to get internal accessed utility room.
this involves removing 70cm length brick wall (double skin, cavity) creating an opening of approx 2.2m. the room dimension is 4m. At either end of this opening are existing brick walls, approx 90cm each end.
so - do i use rsj, or concrete lintel.
how long / what dimensions should it be.
are there any other factors i need to consider.
thanks!
thanks!
