RSJ - remove or leave it?
13 Sep 2009
Lancashire
View media item 30307 View media item 30308 View media item 30310
I intend to brick up between my two lounges downstairs. The rsj shown is 2500mmx150mmx150mm and is supporting a main structural wall. It appears to be oversized and thicker than i would like in comparison to the thickness of the wall; hence plaster work has been plastered over the rsj creating a bump which meets back up with the cornice.
Would it be best to completely remove rsj therefore achieving a flatter wall without the bump covering the oversized rsj, or leave rsj and brick back up under it. If total removal i would have to get someone in to do it, but if can leave it, is it ok to use thermalite block as rsj is still bearing weight above?
Not answering your question but, Why not fit doors to the opening, have the best of both?
Removal, for cosmetic reasons is simply up to you. Also, I would consider whether you wish to reinstate the opening later on.
If you do remove then yes, it will be ok to use thermalite blocks.
