- Joined
- 26 Jan 2005
- Messages
- 266
- Reaction score
- 0
- Country
I am removing some french doors and blocking up with a stud wall - see another post for details.
The doors are not original and an RSJ has been put in to support the wall above.
When I removed the plaster last night the RSJ only overlaps the bricks at the edge of the doors by approx 5 inches. The distance between the outer walls and the french doors is probably 18 inches, so I was expecting the RSJ to reach almost to the walls. As it is the upper wall above the RSJ is being supported by the RSJ which is only really being supported by one brick at either side.
Is this OK, or should a longer RSJ have been used? Note that this was probably done years ago, so doesn't need to adhere to building regs as such, just be safe.
