RSJ/Universal Beam
16 Feb 2005
I'm just about to start trying to source 2 x (203x102x23) Grade 43. Length = 2.75m universal beams that will be bolted together at 600c/c with M16 bolts.
Where do most people get them from? I'm based in the northwest.
Cheers,
Saying your in the Northwest doesn't really narrow it down that much but if you are east lancashire then Mercers Blackburn stock RSJ's and they will cut to lenth and delivery if you are in their delivery area.
Failing that try K steels, but they have always seemed a little on the expensive side to me. especially for a one off order.
cheers for your help.
Hopefully there is something similar in the Warrington area. ??
Hi Paul, I've got 4 of these in my garden at 3m, left over from anothe project. (I'm in London though) Out of interest what are you using them for?
I was wondering if I could use them in a future loft conversion. (At least a year away, probably longer)
If I were to get these professionally spliced to make 2, 6 metre beams could they be used to convert the loft? Obviously I'd need a structural engineer to do the necessary calcs before proceeding but I'd like to know if they are worth hanging onto for future use, otherwise I'll take 'em down the scrapyard.
Anyone else know if these are strong enough for loft floors?
i'm just having a wall removed downstairs so need to replace it with the two UB's.
So are these going back to back to support a double skin brick or block wall? or bolted end to end for a 5m opening?
Cheers
Cheers
side to side to support a double skin brick wall and chimney above. bolted together at 600/c/c
or the blacksmiths in hollins green he'll cut them to length drill the holes to bolt them together and provide the spacers and threaded bar and nuts washers and also red lead them for you
Paul_GPvR said:
Cheers,
Steel suppliers? Either yell.com or yellow pages.
I thought there used to be quite a few up north. They've not all closed down now have they?
