rsj
3 Jul 2007
Ipswich
3800mm span what size rsj should be used taking the sag of a truss on a inner wall of a bungalow if i knocked the wall down the exsisting wall is 100 mm thick?
What about a 150 concrete lintel. lol
Don't sue me if it falls down though
Correct me if I'm wrong, but trusses are self-supporting, so don't normally require a central support.
Otherwise, you need to post more details and the old guy from your neck of the woods can comment
yeah i know but the client wants to store quite of bit of stuff in his loft:cool:
Then you need to know how much stuff is going to be stored, so that you don't have a beam just good enough for the trusses
Not only that, picking a truss up if it's not at a node point may cause an issue.
