I'm having a door moved to butt up against a window, the new opening in the wall will be some 4m in length. We tried to find a lintel to cover the length but it's too big, so we had to opt for 2 RSJs, sledgehammer to crack a nut etc I know but there you are....
My question is that the RSJs are sitting in my driveway waiting for the builders to arrive in a weeks time and I've measured them at 145mm wide. So, bolt the 2 together and that makes 290mm, which is fine apart from the wall is only 260mm!! I have said that I'm going to render above the window and door, but how thick would render normally be?
I would really like any pointers/guidelines on how RSJs should be installed, so that I can keep a watchful eye as the job is being done and ask the right questions. I'd also like to know whether RSJs come in standard sizes and if so what they are. Could the steel yard have got the order wrong?
Cheers
JD
Cheers
JD
