RTU5024 GSM Gate Opener GSM Remote Switch
26 Oct 2023
Does anyone know how to test one of these? It’s brand new with a working SIM card from a previously same model but the SIM card holder was broken
I’ve powered it up and it’s got mobile signal with a slow flashing red led and I’ve connected a 12V pc case fan into the following for testing the relay:
COM: Black negative wire to fan
NC: Red positive wire to fan
This was my thinking to prove that it can work with the existing magnetic gate
I have the instructions which I will attach on here. It just doesn’t seem to respond to a request to turn the relay on so I think I need fo add my number as the authorised number or make it respond to any number using the relevant commands below
Turn relay on
1234#ON#
Set authorised number (this is the one from the manual and looks like an extra digit in error?)
1234#TEL0044 13500001111#01
Setup allow all call in numbers to access it
1234#AA#
It’s a relay how is it going to run a fan ? You need to connect 12v + into the relay common and fan into normally open , the fan 0v to psu 0v
Hi mate, yes thanks for that the problem I’m having is it doesn’t respond to any command I sent to it and it’s supposed to text me back confirming when I’ve made a change to it. There is an app but it says it’s not available in this region, I’m in the UK so I also tried to VPN to change my IP to the USA and it’s still blocked it
I tried to but it doesn’t acknowledge any commands by reply sms like it says it supposed too
A simple test is to put the SIM into a working phone and try to dial another, it may be that the SIM is no longer active. Some regions are turning off 2G networks....and some operators are disabling PAYG SIMs if they've made no chargeable call recently.
In the UK, 2G will be switched off by 2033, but 3G will be sunsetted sooner. Vodafone will begin switching off their 3G network this month, other networks have later deadlines in the next couple of years, all of which can be found at the Ofcom website.
