My daughter has just had an en-suite built. The ceramic tiles used were of a neutral colour and a slight satin finish.
The work is now complete, but the tiles look a light lighter than they should and the satin finish seems to have disappeared, there are also runs from tile to tile.
My suspicion is that the tiler did not remove the grouting until it was hard, then had to use some sort of abrasive and perhaps some chemicals to clean the tiles.
The builder naturally denies this and maintains that tiles simply vary slightly in colour, also that there is some grouting dust still on the surfaces. He has no explanation for the runs.
The situation right now is that he is going to wash them all down to remove any dust, I know this will make no difference as I have already done it. He also said he would look into a showroom to see if they had anything to coat them with (not sure why).
My options are limited. I do not really want all the tiles replaced, it will be a mega job, and he has given no indication that he is even considering such a thing, however I am concerned that if the surface has been damaged then they could eventually become porous.
I am attaching some pictures, in album DRDR but you may need to blow up the pictures to see the runs and changes in colour. The flash makes it worse.
Any advice or suggestions as to what actions I should take would be appreciated
