The Magnaclean on my boiler is leaking so I isolated it turning the two black valves to the off position. I have ordered a new seal but in the meantime is it safe to use the boiler just for Hot water while keeping the Central heating switched off. Boiler is a Worcester Greenstar 29CDi (Combi).
Just want to check if it is potentially dangerous or could damange running the hot water with Magnaclean isolated.
When this happaned I also noticed the Magnclean is on the flow pipe directly under the boiler, so in effect is this the same as isolating the central heating flow (and return?
