Hi. I have a recently installed open-vented, fully pumped Y-plan heating and hot-water system. Yesterday the heating wouldn't switch off. I could hear the microswitch in the room stat click when it was turned down but the neon stayed on. I've noticed also that when the heating is off at the programmer the neon has always flickered faintly when the room temp drops below the set temp. Should it do that? The stat is a ty 92 A1 from Grasslin UK. The boiler is a Vaillant emax pro. Today all seems normal apart from the flicker. Any advice gratefully received.
Cheers
Cheers
