Keeping it brief, I have multiple sockets fed from a single fused spur. I want to reduce the load on the spur so that one socket (red) is supplied from a different socket (blue). This would require running a cable around a corner horizontally at mid height.
I can’t run the cable up and around because one wall has a false ceiling for spot lights and the other side has a boiler with lots of water and gas pipes. Theres also a support beam which is problematic.
Is there any issue with just running the cable horizontally between the blue and red sockets? I was thinking about adding it as a fused spur and not extending the ring.
