I have a Worcester-Bosch heatslave 20/25 oil fired boiler.
I am removing all the radiators form the house as they will be replaced with UFH for all rooms and the oil boiler will eventually go too.
Currently I have 3 radiators still connected to the boiler (Which is on it's last legs but I have a lot of oil still) so want to remove the rest of the radiators but still be able to use for hot water for the moment - till it runs out of oil.
Can I just remove the plumbing that goes out to the radiators and plumb it straight back into itself - just 50cm of pipework?
If the pressure on the radiators is too low I know the boiler won't fire so need the pipework connected but just want to make sure the boiler doesn't need a radiator heat-sink in case overheating for safety?
Thanks in advance
Dan
Thanks in advance
Dan
