Good evening all
I have just moved into our new house built 1930's and have found that some kind soul has concreted over the main stop cock. I need to replace it as I am moving some pipes out of the concrete floor as they look like they have no denso or anything on them and don't want to chance it.
I have tried to shut off the mains in the road but my toby key is too short. I have lifted the floor and have found the mains coming into the property underneath the stairs, I have run a new 15mm mains in to a stop cock and now have the new pipe side by side with the old still live incomer.
I have used a rems machine for all the fittings and have borrowed a freeze master machine which I hope to use to freeze the 15mm copper incomer
What I would like advice on is whether the freezing machine will freeze a live main and if so how long does it need to be left on the pipe for. I intend to fit a lever valve onto the pipe and then connect up my new mains to it. Should I use Jet blue to lubricate the olives ?
Many thanks in advance.
