I've searched long and hard for an answer to this with no avail so I'm hoping one of you guys can help me! I'm in the process of rewiring my house. I've removed the old wiring and it was run upstairs under the floor boards in channels, around half an inch deep, cut out of the joists, where it had to cross them. Is it ok to run the cable through the same path without drilling holes in the joists providing the tops are secured with some metal protection?
Also, when running cable in the loft, the old wiring was previously running over the joists - the majority of the joists are only about 3" high apart from the main joist at the centre of the house, therefore it is impossible to drill holes to pass the cable through at the acceptable depths - in this case is it possible to run cable over the joists in conduit?
Any help appreciated!
