My house is being rewired this week. At the same time I am running cat6 to 3 bedrooms and 2 reception rooms. All from an under-stairs cabinet.
My electrician was asking me how/where I was going to run my cables and he suggested I just run them next to his power cables; saves me having to chase more channels.
I said I was worried about interfence, etc, and he said not to.
So, is running network cable next to power cable a 100% no-no? Or is it just not recommended? Will it make any difference? If so, will it actually be discernable in a domestic environment?
I'm spending a few hundred quid doing this and now is the time to get it right; but, is the time, effort, mess and expense of running in separate channels, cutting floor boards, drilling holes in joists* and making good afterwards worth it? At the end of the day, I guess only I can decide that, but I'm still asking here.
* Downstairs is ok - there is a void just big enough to crawl into and route cables. However, upstairs is an issue and will require crossing many joists.
Edit: I may as well ask while I'm here - what are the guidelines for cutting into joists?
The DIYnot 'How To' simply states:
But I need to route 4 x cat6 in one direction and 8 x cat6 in another, so I'm concerned they won't fit in any holes that meet spec.
The joists will have to be drilled approximately 50mm (2 inches) from the top, large enough for the cable to be able to get through. When the holes have been drilled, threadle through the length of cable.
