running ch and h/cw pipes in kitchen behind units
3 Aug 2005
Warwickshire
I am having a forth bedroom/kitchen extension built and its got the plumbing stage of the build. I am having a galley style kitchen with two straight runs each side of units.
I have to take the CW main up the one wall in the corner over the ceiling and back down to the sink area I also have to run some CH pipes down in the corners to feed 2 plinth heaters.
I would like to know what the best way to install the pipes so that when I come to install the units I wont have to cut around pipes - Should I be sinking the pipes into the wall or should I be running the pipes inside the units in the void at the back.
Thanks in advance
Clip the pipes to the wall and then let into the rear of the base carcasses as required ... DO NOT sink into the wall.
Make sure any pipes carrying hot water are kept away from the cold mains.
