Hi all
Apologies if this is in the wrong section.
Due to the location of my internet switch I would like to run a cable from the switch located in the loft, through the bottom of the soffit and down the outside wall (will be partially concealed behind a rain water pipe) and then into a room that has no internet port/poor wifi, this would then have a direct route to the switch in that room.
Can this be done using an appropriate conduit to obviously protect it from the elements or should it not be done this way full stop?
Thank you for the advice in anticipation
Gaz
Gaz
