Hi. I hope somone can advise me. I want to run HDMI/speaker/telephone cables in the floor rather than going up and over. My builder has cut a channel in the screed and says it's ok to set in 1 1/2" x 12" plastic trunking and to then fill round it and over it with a straight cement and water mix. I am not sure he has channelled it out deep enough - there will be only about 1/4" cement above the plastic - and I think it might crack, give way and crush the cables - not to mention ruin the carpet, when we run the sofas/piano over it.
Does anyone have a view as to whether it is acceptable to use plastic trunking in the floor and if so, should I secure the underside of it to the bottom of the cut out channed (Gripfill?) to stop it floating up when I cement round it, and, most critically, how thick does the cement need to be above the plastic? Also, should I give it a quick splash of pva 50/50 before putting in the cement.
If anyone has any thoughts on this I would be grateful.
Thanks.
Thanks.
