I will be wanting to add a new inlet (from a ground floor extension) to an existing 1930's rigid Pipe foul drain system, which from what I can judge From Thames Waters guidance literature - is a 'Private' sewer
I perceive allowing inward connections to an access chamber at the side of the property - currently there is the existing concrete chamber there - with half rigid pipes running through and out of the chamber.
Reading Building Regs document H, 2.53 - guidance is given on how branches entering should be run:
https://assets.publishing.service.g...achment_data/file/442889/BR_PDF_AD_H_2015.pdf
Is it feasible to add new inlets to the existing or would you replace the manhole altogether, it has been suggested that replacement may create more issues than its worth - then again a blocked drain at 11pm is also an issue.
Any thoughts appreciated.
