Hi, Looking for some information on powering a log cabin but also a garage which is between the cabin and house. My intention is to run armoured cable to the pod via the garage. Once finished I will get an electrician to check, test and connect to the consumer unit. So the question is what the correct method(s) to connect through at the garage. The garage will have a single LED light and a couple of sockets. The pod will run a small heater, TV and a few other things. I am happy working out max current / Kilowatts for appliances and also the length of run so i can size the cable. I'm unsure about how to split the feed at the garage. Do i fit a small consumer unit in the garage and use one output straight onto the pod and another to feed the garage ring or is there a better way. Thanks in advance.
