Running services under attic trusses
28 Oct 2008
Shetland
I am planning a new house (for me) which will have rooms in the roof. As it is a new, very airtight house it will have a mechanical ventilation system which will require ducting to most of the rooms.
Is there a standard way of running services under attic trusses? Do you create a false ceiling and run all the services in the void? (If so, how do you do it?) I could go for Posi-Attic trusses which would solve the problem but I am not sure which solution would leave me with the most headroom.
Any advice?
What size trunking are we talking?
You can get fairly discreet stuff maybe only a 70 or 80mm tall.
I am assuming that at least some of the ducting will be 100 mm (or more).
I think we need a bit more info'.
When you say a ventillation system, what exactly do you mean?
Do you have a link?
Have a look at the pictures on this link.
http://www.villavent.co.uk/pdf/self_build_project_guide.pdf
The main unit is mounted in a cupboard or loft and the supply and extract ducts then run to most rooms. Good practice seems to be to use solid ducting rather than flexible because you get a better airflow. Depending on the size and power of the machine, the ducts that leave the machine are often about 150mm but as they branch they become smaller.
