Running Sink Waste Pipe.
24 Jun 2010
Antrim
I'm putting in a new bathroom and was looking for some advice,
The Sink will not be on an outside wall and the soil stack is on the opposite wall. This is only a problem because the Joists run against it so would have to drill through the joists to put the waste in.
As I see it I have 3 choices.
1. Box the waste.... Really don't want to do this..
2. Run the pipe out the other outside wall and around the corner on the outside wall --- Is this permitted ?
3. Run the pipe down and up again under the bath and out its waste.... Would this cause problems due to pipes going up and down rather then flowing correctly ?
Any suggestions thoughts ?
1. not the best option but sometimes the only way to go
2. depends on length of pipe to stack and route to keep constant correct fall to avoid blockages/freezing, but possible
3. no, it just wont work
4. as a last resort you can pump the waste up and down, (archimedeis spellcheck req'd, pump)
