I have a telephone extension (installed before me) run from the master socket surface mount round a number of doors ways, through walls etc and it looks unsightly so as I'm decorating some of the rooms it passes through I thought I'd sort it out.
I have a couple of options on where to install the extension socket but the route the cable would take is quite similar for both. The easiest route to get a cable into the wall (Wall A) would actually mean running it down into the wall alongside existing ring main wiring, (pull ring main up, attach cable, pull down again) but I'm aware data cabling next to power is a bad thing. I then found another possible location (Wall B) where the cable could come down the wall away from power cabling.
However, working back towards the master socket under other boards, I've found that another extension and I think even the master socket cabling both run through joists alongside ring main power cables - this would have been done when property was first built ~20 years ago. So I'm wondering how important it is to keep the telephone extension away from power (now knowing it's already done been in a few places)? Can't find much in the way of shielded telecoms wiring online to minimise potential EMI. Anyone had any experience of this?
