Hello,
I've just been into the loft to find a water mark on the loft boarding. I've taken the insulation off to reveal a rusted section of pipe. (see pictures).
The pipe was probably fitted int he 1970's so is likely to be imperial. I've measured around the pipe and it's about 4 1/4 inches. I've worked out that it's probably around 35mm diameter pipe (there's a 28mm copper pipe next to it for comparison).
What's the best way of joining a new section of pipe with imperial to metric and steel to copper ? I'd like to know:-
- Is there a plastic pushfit option to avoid copper to steel corrosion?
- What's the best way to cut the steel pipe - any tips?
- Why did it rust?
I'm off out this afternoon so may not be able to reply immediately but I'll be back later today and any help would be very much appreciated.
Kind Regards,
Will
- Why did it rust?
Kind Regards,
Will
