I need to replace the syphon on my cistern but the wingnuts are rusted to the threaded lengths of fixing bolt. Are there any tricks to removing the wing nuts without snapping them off? I've sprayed lubricating fluid and left to soak in but they won't budge
Cut them off - any way you can. Just check that they don't pass through the cistern itself first though. If they don't, arm yourself with a new close couple kit.
John
As five or six other people have already said, you'll probably need to cut them off. However, which lubrication fluid(s) have you tried? A good squirt of PlusGas will free off many a seized part, especially if you can work it back and forward a turn or so to get the fluid into the threads.
