They've got a rubber washer under the cap. If you're unlucky then the gorilla who used them before you will have screwed them down so tight that they've forced the washer into the vent hole.
Are there "manual" vents that don't have to be fully removed, ie, when you unscrew them so far, the air/water escapes up through the center of the cap and out the side of it with suitably drillings?. I'm sure I've seen something like this used to relieve pressure before fully removing the cap or whatever fully (different application).
