- Joined
- 13 Mar 2005
- Messages
- 26
- Reaction score
- 0
- Country
My boiler is operated by a Siemens RWB9 programmer, this operates the heating and water, or rather it did until this week. Now, even though all the lights are on to indicate the system is turned on, the boiler doesn't fire. If I press the control unit the boiler starts up. I guess indicating a connection fault regarding the control unit. I've taken the unit off the backing plate, cleaned all connections (although they look fine) replaced the unit but it's still the same. The fault only seems apparent after the unit has been off for a while, It doesn't turn back on using the timer. I've reset the unit but still the fault persists. Any other ideas before I buy a new control unit.
I'll try taking the unit apart tonight to see if there's a connection fault in the unit. Strange this as the unit just sits on the wall and all I did recently was change the operating times. It's not worked since.
All thermostats are OK. Nothing has changed with these.The unit has an "advance" function which advances the operation onto the next setting. This morning the boiler didn't start, by the time I'd got up the timer has scrolled through to off anyway. Pressing "advance" turned the boiler on.
The boiler doesn't start at all on the timer. If I press on the timer unit it starts and operates as normal. Turning on and off via the thermostat.
It worked fine all day yesterday (after I'd got it going), but after it's been off for a while the control unit doesn't activate the boiler, although the 2 lights are on to indicate operation of the heating and hot water.
Any further ideas other than the timer unit is playing up?
My system is gravity fed heating with a 2 port valve on the heating but nothing on the hot water, so the heating can only be on with the hot water.
(Yes I know not the best system. I'm trying to find someone to plumb in another valve on the hot water side who doesn't charge an extortionate amount.)
