Hello,
I wonder if anyone can help with this query. We have a 100mm square RWP that needs connection into circular below ground drainage pipe work. Is there a socket/connector that will enable a square fitting of this size to securely connect to the below ground drainage ? Or do we need to utilise a gulley, if so can the pipe connect inside rather than discharge above into a grating .
Regards,
Graham
Regards,
Graham
