Ryobi EPS80RS Sanding Sheets?
6 Jan 2009
Limerick, Munster
Ireland
Folks,
I have a Ryobi EPS80RS Mouse Sander - I need a ton of replacement sanding sheets for it, as I have a bucket of detail work coming up.
I can't tell easily if any of the generic sheets from Amazon like this one, will fit it.
Are these all fairly compatible, and I can go ahead and order safely?
Ray K
Although sanding sheets look the same they often aren't the same because of slight variations in size or shape.
What I have done in the past is to go to the likes of B&Q or Homebase with my sander, selected a pack of what looks suitable then asked permission to open it and check. If they fit I buy the pack but then order further packs on Amazon.
Try to match up the holes in the sole plate if you can, Ray - it'll make any dust extraction better. Hook and loop sheets for me!
John :)
When I run out of paper for my small Festool delta sander I just use a stanley knife to cut a piece from one of the larger sander's paper. I then use a hole punch or screw driver to make the dust extraction holes.
When feeling particularly lazy. I just use the whole oversized sheet of paper and fold it as appropriate. It has the advantage/disadvantage of sanding the edge I want to sand and any meeting edge.
