S Plan Pumps over when hot water valve opens
17 Nov 2012
Lancashire
I have taken the expansion pipe about a meter above the tank but it still pumps over. Tank does not overflow so I have ruled out a faulty coil in the cylinder.
It does not pump over if just the heating is on but does whenever the hot water valve opens.
This doesn't make sense to me.
Any ideas??
Dan can you elaborate a bit please? The 22mm vent is taken off the flow just before the 2 motorised valves. I am not sure where the feed is connected in, where should it be? - Jon
And where is the pump? Just before the vent?
