Hi
Great forum btw!
I have a Vaillant EcoTech 418, S-Plan system, 2 zones (HW unvented cylinder + CH), installed 1 year ago. Standard 3 speed Grundfos pump.
The system seems to work, but boiler periodically (say once a month) cuts out with error F72... "Flow and/or return NTC fault".
I've now found out the system does not have a bypass loop/valve (I'll get one installed asap).
Q1:
Without a bypass valve, the pump over-run didn't seem to cause any obvious problems. I mean... should the pump not rattle and shake if it's pumping with nowhere to go? Or will it just overheat but keep running?
Q2:
Without a bypass, should I not see the temperature on the display of the boiler spike up every time demand stops (i.e. during the overrun)?
According to the display, the temperature stays high, but doesn't increase (of course if may spike sometimes when I'm not looking; I've never witnessed the F72 error happen in real time; it only happened after CH and HW have been on at the same time... maybe the extra power that requires can cause the overheating?).
Q3:
What kind of damage could take place from running the system with no bypass for a whole winter? I guess my pump didn't love the experience...
But could I have damaged the boiler?
Many thanks
SgtFoley
Great forum btw!
Q1:
Q2:
Q3:
Many thanks
SgtFoley
