Hi there, I've been going through the forum for the past few weeks and have read every single S53 thread on here.
My boiler, an Easicom 28, when it starts up heats the radiators very slowly and takes ages to reach the target flow temperature. I discovered that it was throwing up a code S53.
I have balanced the system as suggested in the other threads, is there any possibility that the main heat exchanger can cause this if it is blocked?
I had an issue with my hot water last year where the hot water kept fluctuating, the heat exchanger plate was clogged with muck, it was cleaned with acid and this sorted out the issue....for 3 months until it happened again. This time I had a new plate installed by Vaillant. When I described the symptoms to him about the slow heating he suggested that the main heat exchanger was likely to be clogged with the same stuff as what was in the heat exchanger plate. He changed the pump to a brand new but I've still had the same issue and it now takes even long to heat up the radiators.
I had a powerflush done last year and very little stuff came out, I have inhibitor in the system and a magnaclean (which when I checked today, a year after the powerflush did have some sludge over it).
Any advice, comments would be appreciated.
