I have been stripping several layers of paint from my banisters, using Nitro Mors. I know that some of the layers contain lead.
I have since found out that I have perhaps not been as careful as I should have been and I still have some more paint to remove.
I was under the impression that as I was not doing any form of sanding, then I didn't need to use a vacuum cleaner with HEPA filter, so have been using a standard hoover.
As I have been doing this job over a few months, the paint is flaking off next to the completed areas. These flakes have spread around the house, and some are attached to the floor or in crevices on the banisters.
I have also not been rigorous about making sure that any of the removed paint flakes did not spread around the house, although I have cleaned up after evey day's work.
Can anybody suggest what I should do next? Should I hire a specialist to complete the work? If so, would a painter/decorator be suitable? Or will I be OK to complete the work, and perhaps hire a HEPA vacuum cleaner to clean up afterwards.
Although there are no children in the house, I want to be sure that it won't cause any visitors any harm, or to any children that my wife and I may have in the future.
Thanks in advance
Thanks in advance
