Hi all,
Just a quick question. Apologies if wrong section but I thought roofing might be my best bet.
I've got to strip back, treat and repaint some weatherboard on my house. One particular section is above an extension with a double glazed glass roof that joins onto the old out building which measures about 2m by 4m. It is one large panel sat on top of the beams.
It hasn't been done since before the previous owners did the extension so I don't think they thought about access. It would be nigh on impossible to get a scaffold tower up and over the roof due to the lay of the land/neighbours property.
So my only option is to go onto the glass roof. My plan was to put a tarp down to protect the glass, then lay scaffold boards across the glass, perpendicular to the beams to spread the weight. Then a sheet of ply across the boards. It would only be my weight up there (about 90kg) and a ladder.
Would the above set up be safe/doable? Last thing I want is to crack/damage the glass roof or go through it myself.
Thanks all
Thanks all
