- Joined
- 12 Sep 2007
- Messages
- 72
- Reaction score
- 0
- Country
can i ask for a number of opinions on this small matter
why is it that safety zones are ran down each side of the wall and horizontally/ vertically from all sockets?
if you are fitting kitchen wall units against a back wall you always fasten the units right in the corner (or at least it is possible to) therefore going straight through the mentioned safety zone cable?
also, is it possible to run a cable horizontally from an all ready installed socket, around a corner of a room into another socket? reason for this is due to a window preventing from dropping a cable from above. therefore, if the ground is concrete, this is the only way to route a cable in a "safety zone". if you are required to bury all cables.
I look forward to opinions on this if you have the time.
many thanks
P.S. these are all queries, i understand about part p and building control etc. just hoping i may have your opinion, thanks in advance!
many thanks
