Evening all,
Really hoping I can get a speedy response to some help required as I am in the middle of finishing my floors and need them completed for next weekend as I've got the new furniture arriving!
Right, I sanded the living room oak floors over the weekend and went to a real fine grit and got a lovely smooth finish.
After thoroughly cleaning, I applied a coat of Saicos Hardwax oil, that's now dried and the finish is a bit rough!
Admittedly I have yet to put the required second coat on, but without wishing to state the obvious know hat the second coat will not all of a sudden dry to a perfect finish.
Okay, I've experimented on an un obvious section with two techniques, one was to wire wool and the second was to use 320 grit in between coats paper. Both reveal extremely good results, and require relatively little effort to get a good finish.
My only problem with this is that I have around 35 metres square to go and this will take an extremely long time to do, especially if I have to do again after the second coat!
If this is what I have to do, then fine, I'll accept it stop moaning and get on with it! But if anyone has any suggestions, I would be more than great full to listen.
Many thanks......
Chris
Many thanks......
Chris
