Hi all,
Im just doing a bit of home improvement in my bathroom and need to install a pump due to the pitifully low hot water flow, but need a little advice. Im looking to buy a Salamander ESP CPV type pump as I need a joint negative/positive head pump to serve the shower head which is at the same height as the cold water tank in the loft, as well as the bath which has enough of a gravity fed flow to kick start a positive head pump.
However, my question is, will the pump automatically toggle itself between negative and positive head as appropriate? i.e. if I run the bath using the positive head and then afterwards decide to use the shower head for any reason, will the pump be able switch without me doing anything to it?
Apologies if this is a really basic question, but I dont want to go spending £200-£300 on a pump that wont do what I need it to.
Many thanks in advance for any help.
Peter
Peter
