Hi All,
Have searched and searched the forum for this particular problem and whilst I can see many other queries and problems related to Salamander pumps, I can't see any that are the same as mine.
I have a Salamander ESP 75 CPV twin fitted in the airing cupboard on the floor next to the hot water cylinder. The pump runs all of the upstairs outlets (2 x basin, 2 x shower, 2 x toilet cisterns and a bath) as well as two hot taps downstairs. All has been fine for over 4 years (except that the seals on the hot side of the pump needed replacing about 18 months ago). Last night, the pump suddenly made some additional noise while running - didn't sound good, and the immediate symptom was that the hot water had less pressure than the cold at all outlets. Annoying, but not the end of the world. Today though, there is a also a problem with the temperature although the noise problem has gone. To cut a long story short, I've determined that the hot water is perfectly hot at all outlets when the pump is off, albeit not at anywhere near decent pressure of course upstairs. When the pump is turned back on, the pressure returns but the previously hot water soon turns lukewarm at best. Turn the pump off and the water slows but gets hot again. And so on...
Will speak to Salamander tomorrow but any clues in the meantime would be much appreciated.
Cheers,
Cheers,
