We recently had installed a Salamander RHP50 pump in our bungalow to boost our shower pressure. At first everything was fine but then the pump started making strangled screeching noises and also pulsing. There were also lots of black bits - looking a bit like swarf coming from the taps. We complained to Salamander and one of their engineers came and fitted a new pump on September 25. The inlet filters on the old pump were completely clear. This one shortly began to exhibit the same symptoms so we complained again and had yet another pump fitted on October 6. this one managed to work for all of 9 days before it, too began to make horrible noises and spew out lots of black bits - these coming, seemingly from only the hot output of the pump. On October 24 my wife had a shower without incident. When I went to showere 15 minutes later the pump didn't work and has not worked since! I checked the filters and they were completely clear although the kitchen and bath tap filters were well clogged up with the usual black bits. Neither of the two Salamander engineers had found anything wrong with the installation. It seems to me that the impellers on the hot side are binding then breaking up. There is nothing wrong with the water flows to the pump and the domestic hot water temperature is only 56 degrees. Salamanders reaction is to send me, by carrier, yet another pump and have offered no opinion as to what may be wrong. Any ideas anyone?
From Traumatised Tony (77)
