My salamander pump (RSP100 2 bar pump) supporting 2 showers, works most times, but then once it has been used, and switched off, will not work again, starts pulsing, for another 15-30mins. But this is not alsways the case. it will usually come on again in the evening, or the following morning
Somedays it will not work first thing in the morning. Which is usually followed by screams of "get it fixed" else Ill cut your whatists off!
I have read on here that I should put a non return valve in the hot pipe output to the shower.
Is this correct? or do I have to put them in both pipes to the showers.
Or is there something else I need to do like put an automatic bleed valve in both pipes.
or should I just buy a positive head pump?
The pump is located by the side of the bottom of the Hot water tank, and is at least 1.2 meters below the 80L cold water tank.
I have cleaned the filters, and checked the cold water tank so it hasnt emptied.
