Had a new Bathroom suite fitted in Apri/May of this year.
The original pump used for many years without issues was a Showerforce Easiboost pump.
Having a new bathroom complete with new shower cubicle etc., thought I'd change the shower pump too to a Salamander CT50. Two or Three months down the line it failed. Going through the lengthy warranty proceedure with Salamander, I purchased another Salamander CT75, now this has failed.
In both cases when they failed during a shower, I checked various things and found by burning my fingers the motor body was so hot but no smell of over heating etc. The failed pumps, the impellors can be rotated, but if the motors are switched on there appears to be a arcing sound not a buzzing sound as when motors are stalled or will not turn etc
Did a flow test from the rainwater head for both HW and CW each for 2ltrs at 1min 20secs. The base of the cold water storage tank is approx 60cm above the rainwater head. There are no kinks etc in the anti-vibration pipes as they are virtually straight.
Now Salamander are saying I should have used a negative head pump. Since I have put the old Showerforce pump back in operation giving as it appears the same performance as the failed pumps. Yet it runs quietly and cool after 2 showers lasting 4/5mins for each person.
So why should one pump run ok and others fail overheating etc.
thanks
thanks
