Salus it500.
24 Nov 2018
As much help as i can get please on how to wire up a it500 reciever to my greenstar 30si boiler.
Not sure which way the wires go into the boiler afer ive removed joint from inside the combi between Lr and Ls...
Ls = (Live supply) goes to the Salus (L) and also CH (Com)
Lr =(Live return) goes to the Salus CH (NO)
Ns = Neutral goes to Salus (N)
If you need to remove a room sealed compartment of your particular boiler to access the wiring terminals, you should employ the services of a Gas Safe engineer to do it so that they can make sure that it is properly sealed up again afterwards.
