Hi guys, i'm in need of some wiring advice. I'm trying to wire up the receiver for the Salus RT300 wireless thermostat. I'm wiring up to a Saunier Duval F30 combi boiler.
The Saunier duval has two options, 1 for a volt free thermostat, the other for a 230ac connection.
The Salus says it can be wired as a 230 or volt free. But it says it needs a permanent 230v ac connection, so i'm a little confused. If a 230ac connection is permanently needed, how do i then connect this to the saunier duvals volt free connection without passing 230 volts through it, blowing the PCB?
Any advice would be much appreciated. I've wired up a couple of volt free thermostats before, but never a wireless gadget like this so dont want to take any chances.
many thanks.
many thanks.
