I've just fitted a Salus RT500RF which has replaced a conventional thermostat on a conventional central heating system. My original thermostat had two connections L & N. I've wired the receiver unit as 230v application (with jump wire) connecting the L & N terminals. The unit red light comes on with heating on, but the RF control (with new batteries, same address code as receiver) does not appear to work when programmed.
Have I wired it correctly? Is there some reset procedure I must do? Is there any test for the RF (when I press ^ it doesn't switch on)
Appreciate any help offered, thanks
