SALUS RT501RF (TX) wirelss timer + boiler problem
2 Feb 2006
a relative has recently had a Baxi Duotec boiler fitted with a wireless stats, model: salus rt501rf.
the problem he tells is me the boiler is coming on at various times of the day outside of the timer set-times, Ive tried to set it up, as far as i can see ive done it correctly but its still coming on outside these pre-set time
Ive set it up as follows:
Monday to sun morning: come on 5am, max temp set as 25C, off at 9am, min temp 10c
Monday to sun evening: come on at 5pm, max temp set as 25C, off at 9pm, min temp 10c
i cant see why it would come on outside of these times, the base temperate Ive intentionally set is 10c so the boiler should not come on outside of these times
can anyone help as the manual is not much help
Sorry to bear bad news but Salus are crap! They pick up signals from everything... Except the ones you want! Apart from binning it and getting a decent RF stat, you can try changing the jumper positions on the back of the unit, so that it works on a different frequency. This did work for mine when I had one but that was years ago and I'd not dream of installing one for a customer (or anyone) again!
You can find resources via Google on how to change the jumpers.
OK thanks ill have a look, im not an expert with electronics but ill give it a go,
does the way Ive set it setup look correct?
also there is another program on the device which i don't understand, programs 1 and 2 are for the morning, programs 3 and 4 are for the evening, then there is a 5th program only to start the boiler but not to stop. surely there should be a 6th
As advised you can easily change the frequency but always go with the lowest one if possible they are more reliable
