Samsung A22 5G Install tunes ?
5 Jan 2010
Norfolk
Is it possible to connect a cable phone to PC and download tunes from Zedge or similar ?
Or is there another way ?
I am not going to be connect to internet with phone it's a PAYG.
Thanks for any assistance.
When you say about installing tunes, do you mean Installing ringtones, or copying music over?
If it is copying music, have your music files (MP3's etc.), in a folder on your PC, copy them to a microSD card and put it into your phone.
If your PC doesn't have a microSD card reader, they are available for less than £5 from Amazon.
Then use the built-in Samsung music app to play them.
If you want to download ringtones from Zedge, the simplest way is to use the Zedge app on your phone. Do you have acces to WiFi at home?
We have WiFi
Just ringtones.
no micro sd reader
But as the phone will be calls ans text not going to be able to load app.
If you have WiFi, then the absolutely simplest way is to connect the phone to the WiFi. Download the app and the ringtones you want.
After that, if you don't wish to use wi-fi any more just turn it off again.
Otherwise, connect the phone to your pc with the USB to USBC cable and transfer the files across.
You can certainly connect that phone to youyr PC with a suitable USB cable.
Samsung has a utility called DeX that runs the phone's screen on the PC and makes file copying very simple.
